am i right tha this method will get you into the 5" and the rage? "Uncle Phil Quote"
Now that I know what to do, it's pretty simple if you can find the right version of the programs. Copy REGEDIT.EXE and JOTKBD.EXE to the sd card, change the NAVPATH to the JOTKBD.EXE first to bring the keyboard up, then change the NAVPATH to the REGEDIT.EXE to bring REGEDIT.EXE up, select CUSER from the dropdown box, double tap OEM, double tap SHELLEX, scroll down to find WINCE, double tap it, edit the first parameter ENABLE to 1, save it and then back out. Then I hit reset to boot the system. I thought at first it did not work because the button didn't show up on the main screen. For my GPS, it puts the WINDOWS CE button under SETTINGS menu - the same place you set the NAV PATH. This deal takes about 5 minutes now that I know the 'how to'.
http://www.adventurebikerider.com/forum/64-about-gps-and-gps-routes/259777-peaklife-vs-rage-gps-systems.html?limit=10&start=40
