Thanks for the prompt replies. If i go into the satellites without primo running, it shows i receive 12 sats. on the gps info, and when i reset these they reset and come back. the co ordinates show my home address. (checked on
http://www.gps-coordinates.net/), so it appears that the device is working, but for some reason will not connect to primo. I have copied primo on to memory card and inserted it, hoping to run primo off the card and not off the device. Although i can select it in the navi path, there muxt be a conflict as it reverts back to the resident flash. I do not want to uninstall primo as i do not want an quibble if i have to return the device.
it was purchased from a third party uk based, and not from chinavision,
- CPU: mstar 2531 800 mhz
- RAM: 128MB
This appears to be the same as the 5" cpu wit 8 gig of memory.
If i set a new route with a new start point it says that it will disable the gps receiver. I tried this hoping at least that the device will start in this country, but when i plan the route and press go, it tells me that the gps receiver is OFF. When i turn ON gps receiver,it asks me if i want to delete my start point and turn on the gps receiver, so i have to do this,and enable gps receiver, it recalculates the route and i end up back in Russia again and when i press the satellite button in top left hand corner it tells me there are no satellites available.
This is so frustrating, and i do not want to break into the device.
Primo is there, it shows all the streets i ask of it, i can create a route but.........................................Primo cannot autodetect GPS receiver, and show me where i live on the map, although as i have stated, the gps info under settings detects upwards of 8 satellites and gives me my home co ordinates.
It has not frozen or sent the memory warning up since i put the calendar away in the top left hand corner. Although i cannot see that STEALING the memory from primo
Many thanks once again
