I have managed to remove all the races using a range of techniques gathered from this forum and ST-riders, would have been nice to have the kit but not possible here in Dubai !
I'm replacing with All Balls taper bearings and have a couple of queries:
1) Should I use waterproof grease ?
2) Should I apply grease to the inside of the dust seal where it contacts the bearing or leave it dry
3) I read about a free fall technique to set the lock nut torque correctly, could someone kindly explain how I do the free fall check
4) I read about overtightening the lock nut to 'seat" the bearings and then back off , this worries me a bit in case it damages the rollers so thought I would double check if this is recommended
5) The inside of my steering stem is very rusty, there is a plastic cap at the bottom but nothing on the top, this seems strange to me, am I missing a part or should I squirt some oil in there or just ignore it and let it rust !
