Update 25.11.2020
Well ladies & Gents,
I thought it was about time , I gave an update on my Electric pan project to date. I have had a few bum steers and followed the wrong paths but think now I am heading on the right one.
I purchase a number of Nissan leaf gen 4 batteries, with a view to buy 14 in total, but I got my calculations wrong , ( i.e. basically 14 wouldn’t fit , were I thought it would in the engine area, )
So, I will need to consider another flexible battery method, but I think I need to start from a base design and adapt accordingly , so as a start I need to build the battery cage, mount in the frame. Then fit the engine in place with a drive shaft connected.
I took the standard Honda drive shaft coupling design, and decided I needed to be able to attach one end to the standard drive shaft splines , and the other would need to match the key way shaft design of the Electric motor.
The universal coupling from the drive shaft to the standard ICE looked like this.
I took the coupling to a local machinists , discussed a few methods to adapt this , and arrived at a design by which , a specific machined items , would be shrunk fit onto the ICE end of the coupling , and welded in place. They made the adapter below, so the coupling would then fit the keyway shaft drive to match the electric motor I have purchased.
Cost for the conversion was £50.
The battery cage was then rough designed, from a 6mm mild steel plate profile and measured up. I made up a rough sketch, then had this manufactured, by a local sheet metalwork company.
Cost roughly about £150
I then trail fitted in the frame as below,
The next task is to mark and cut out, notch the battery cage, so it is a tight fit. Inside the engine bay. Mark, centre punch and drill the bolt holes, so the cage is a solid secure fit inside the engine bay, and too be rigid enough to prevent torsion and twisting of the frame.
Finally, mark out the drive shaft hole, then cut out. Followed by the secure fitting of the modified coupling onto the standard drive and see where is sits (and measure) from the rear plate of the battery cage.
Next task after this, will be to mount the engine in accordance with this measurement, design, fabricate a bracket in mount the engine in place. so, the whole assembly is in line (as straight as possible.)
I will post an update at this point, as I believe this will be the most bespoke and fiddliest part of the project.
Until then Stay safe everyone
regards
Tony
