1129VLD
"71David5"
I'm doing a valve clearance inspection following GetSum's worksheet.
I checked the intake and exhaust valves on cylinder #1 with the timing mark at T1. The position of the cam lobes was as described/pictured, as were the markings on the cams.
I rotated the crank ~90 degrees CCW to T2 to check cylinder #4 The instructions indicate that the cam markings R-EX and R-IN should lined up on the inside .. mine do not and are not even close.
The bike has ~125,000 miles on it. I've checked the valves twice at around 50,000 and 85,000, using a different set of instructions. The right side has been in spec.
The bike did have a shim replaced on the right side at around 24,000 by the dealer (previous owner).
Thoughts? Feel free to call if you like. ( Eight o 5 ) Four 7 ate - ate 6 4 five.
