So I have removed it and grease seems to be dry on the bearing,Also, should I clean and repack them with fresh grease too?
If I'm reading this correctly.. some clarification is needed.
Grease on the outside of the bearing does nothing, what you are probably seeing is dried moly grease from the spline lubes. Those are sealed ball bearings suporting your tail wheel, you can't pull and pack them like tapered wheel bearings. Yes, technically you could pry up the seal, inject some fresh grease underneath. It's debatable if doing this really helps as you are leaving the worn out base grease behind.
You can put some grease on the inside of the bearing, but this just helps the axle slide through and prevent corrosion. Do not use moly grease here, not enough movement.
1 month ago it was fine. Putting on new rubber I got the marble feeling as i was inserting the axle. I extracted the bearings and they had that crunchy feeling after a mineral spirit cleaning.
