jfheilman
jfheath, while I assumed it was out there, I had not really looked for it. It is an option. The only real reason to select it is I get to do the connection and I know the quality of the connection
Exactly the problem...... no where near as "heavy duty" as the cable from Autocom ...
You probably know this already.
Those connectors are available loose and also with length of wires already attached.
I noticed a very marked change in quality in the last mic assemblies that I bought earlier this year.
A quick search for 7 pin din extension cable reveals that they can still be obtained with straight leads. You'd need to check that they were screened for audio use.
For straight 7 pin extension lead
Pretty sure I have a couple of those cables around. My gear was all Starcom, which I think is compatible with Autocom. I have a couple of amps including on digital, BT module, some coiled cables and other stuff lying around since I converted to all wireless. If you need anything, let me know and I'll look around.
