Some interesting facts related to this. I've not written this for about 5 years, so its about time it got an airing.
The Honda spec states a Moly Paste with >40% MoS2
Their first recommendation is for Dow Corning G-n Paste which has only 15-20% MoS2. Not easily available now.
Honda Moly 60 was the preferred option - but it is suspected that this was re-badged G-n Paste, and is no longer produced (see above).
M77 was originally Molykote M77 from Dow Corning. This is stated as being suitable for low to moderate loads and low speeds. It has a Silicone base.
Dow Corning told me that their Molykote M77 paste is Silicone Based and was not suitable for high pressure situations and that ..."Mainly, mineral based oil products like G-n Plus are used for the situations that I described for the final drive of the ST1300". Other versions of M77 are available. M77 is not a registered trade mark of Dow Corning / Dupont. 'Molykote' is.
I have seen a Honda document that states that M77 can be used when the manual asks for Moly 60 - but the document that I have seen was written for the car workshops where Moly 60 is used on the disk pad backing plates. I have never seen it written as a subsitute for the high pressure environment of the rear splines.
It occurs to me that the 40% Molybdenum Disulphide requirement may be a catch-all, a safe layman's criterion, for people looking for a substitute. This may well have been the case when it was written. But that was before the silicone based M-77 product came out.
I contacted Honda UK 5 years ago about this to see what they use on the drive splines. It was interesting that they do not say that they use M77 ! This was the e-mailed reply from Honda Customer Service at Honda UK.
I did some research on your enquiry and also checked with our technical department to see what they would recommend. What we are currently using in our dealerships for such cases, as an alternative to the Honda Moly 60 paste, is the "Motul tech grease 300" and our technicians advised that it should be appropriate for your ST1300 Pan European.
Motul Tech Grease 300 is designed for a high pressure environment, but contains zero Molybdenum Disulphide.
I noted that the reply from Honda did not refer to the drive splines, even though that is what my email asked for. It seemed odd to me - why miss out such a vital piece of information?? I also noted that the reply came from
info.uk.car@honda-eu.com which raises another doubt as to whether or not my question was understood.
So Instead, I went for the Rocol ASP - which is still produced by Rocol, under a new name Dry Moly Paste. They say this is NGLI 3 consistency, but it feels just like the Moly 60 which is NLGI 2. The Rocol has 50% MoS2
But I have noted that the Loctite LB8012 / 51048 Moly Paste seems to be equally up to the job - from comparing the spec sheets and hearing from other members of this forum.
Likewise the T70 mentioned above.
Your Sta-Lube stuff may be up to the job. It is speciifed for Extrem Pressures, has some MoS2 - although we don't know how much, it has the right consistency, But I don't know. And because I don't know, I go with the stuff that is still readily available, and is recommended by Honda. If Rocol wasn't so readily available in the UK, I'd be tempted by the Loctite.
You do well to do the research and ask the questions
@ASPC. We have had many discussions on the forum about what is and is not suitable for the splines and many will yawn at me repeating some of it. But it is difficult to glean the accurate information from the snippets and misunderstandings that may have been obtained. eg like that reply from Honda UK. It seems to suggest that the Motul is OK, but they did not include my email in their reply, and they do not mention the application. So it
may be suitable for the application on the drive splines, but their answer does not say that. It leaves me no wiser.
If you want the emails and data sheets that I kept from this research, I'll happily send them by PM. But this was 2017 - new products may now meet the requirements, but I believe that the latest shop manual still specify Honda Moly 60, and that has not been available for a good number of years. The info from Dow Corning was obtained over the phone. My only record of that is what I have posted on here in 2017. Someone posted the link above.
