Article [13] ST1300 - Electric Windshield Assembly - Remove / Clean / Reinstall
Appreciate all the support from the ST board.
ST1300 owners
Machined & Heat treated replacement gear kits are now in stock.
The gears are machined from heat treated 4140 steel bar stock and will not deteriorate like the OEM powder metal drive gear.
They are a simple drop-in replacement for the Honda gear and provides insurance against total failure and often fixes completely failed mechanisms.
Note that its best to replace the drive gear and clean these expensive assemblies prior to complete failure.
See these threads for further details:
https://www.st-owners.com/forums/show...ent&highlight=
https://www.st-owners.com/forums/show...all&highlight=
ST1300 windshield adjuster gears made by a small shop here in the USA.
Gear kits are still 140$ shipped (anywhere in continental US)(multiple kit orders could be less). The kit includes the replacement gear,a 1.75 oz tube of soap based lithium grease (NLGI#2), and several brushes. Shipments outside the US, on a case by case basis (shipping varies quite a bit) but should be around 160$.
Paypal is preferred. carlermotorcycleparts@gmail.com tell me your general location and the quantity desired.
As always; thanks to everyone who has contributed technically and otherwise.
ricke (warofman9)
Great thread , I need to work on my adjuster, the left side works, right side does not. It would be good to have a gear on hand, hopefully I can reorient the cable as explained. $140 for that little gear and some grease seems a bit expensive ! But what can I do ! I have enquired of availability. Thanks for the details of working on the adjuster assembly. Years ago I had the cowling open and had no idea how the assembly worked nor parts availability, so just closed it up and have suffered along with a one sided adjuster for years. Actually I rarely move my windshield but am ready to get her done right. PLease advise if you are so inclined.
The left side of my adjuster works but the ride side does not, so does that indicate a worn or broken gear or just the right side cable ? Would like to have parts on hand when I open it all up for repair.
Could be one or more of several possible causes. Difficult to know without a look.
For instance, one situation here
About the only sure way to have all the bases covered when you get into it would be to have a complete new assembly on hand....which you probably want to avoid if you can.
Tor instance, one situation here
Interesting, just a broken DOG
The broken dog is most likely not the primary cause of the failure. If you keep operating the screen like he did, with one side jammed, there is a good chance the dog will end up snapping
This was just to illustrate that it is difficult to predict what you are going to find once you get into it.
One of my ST13's has the same issue. The lower ear on one dog or the other snaps off, once the lube gets dirty and dry enough that the dog jams in it's track. Using it further, without repair or service will soon result in the lower ear of the other dog (slider) snapping off too. I don't raise the shield much or often (as I added a Laminar Lip),,, but I have the items needed to fix it. Maybe this winter,,, cheers, CAt'
Anyone have an answer for my out of alignment windscreen mounting arms? The windshield was sticking, so I removed it and popped up the inner black plastic cover and lubricated the cable/track area. Started working smooth. Problem is I ran it up and down a couple of times to check it and it got out of alignment. One side higher than the other. I can't even mount the windshield now.
Any idea of how to adjust the mounting arms?
Thanks!
Alan
Thanks!
Alan
Each side is activated by its own separate "threaded" cable riding on the same gear.
If one side rides higher than the other, chances are that one of the cables is starting to strip or the gear is getting worn where the cable engages it.
You'd have to take the mechanism down to check it (not a 5 min job, unfortunately, but can be done if patient).
If it turns out the cable is still OK but the gear is starting to wear out, some have been able to shim the gear housing to shift the gear point of engagement.
If the cable is worn, best is to go for the Bike QUIP replacement parts.
Very well thought out kit I hear from somebody who successfully repaired his windshield mechanism with it.
Key for prolonging the life of the mechanism is to not operate it at speed (especially not raising it at speed).
Two documents:
1st - Removal of the Electric Windshield Assembly
2nd - Clean and Reinstall
I've just completed removing, disassembling, cleaning, lubricating and re-assembling my ST1300 Window Adjustment Mechanism with success! Whitout your article i could not have done this.
So thank your very much!
Best regards, Ruud Luijkx
Netherlands
I was thumbing through eBay yesterday and came across a brand new windshield mechanism for $415 (plus shipping and tax) So I offered $375 he countered with $400, so I bought it. Looking at Partzilla, they want $720 for a new one. I'll toss it in my parts bin for now.
In the meantime, I need to go through the used/broken ones I have now and pick out one to rebuild for the AZ05 bike project, I'm building.
AZ05 Build
AZ05 Build
Yep, it probably sat in a Arizona Wearhouse for many years, the grease had melted to the point there wasn't much left in it! :redface-2x:
So I tore it apart and cleaned it. And I'm now reassembling it.
