I've been using a Digisync for a few years now for all my carbed toys. It works exceedingly well.
Thanks for the info! Will be heading out to find one today!Trying to edit my last post, needs to be long enough to clear the Air cleaner, which I leave on. Bright flash light helps to see the adjuster screws
Might consider one in the future if I see one available!I've been using a Digisync for a few years now for all my carbed toys. It works exceedingly well.
Does less bodywork have to come off if I’m going to use the syncrometer? If that’s the case it would 100% be worth it hahaI’ve used the SK Syncrometer since I’ve owned my ST. It is fast to do and you get better at it each time you use it. You get to learn the sound of the bike when all 4 carbs hum in unison. Good luck.
Not really less work, you have to take the air filter off which means the fake gas tank cover comes off, the seat and the sides are coming off. It gets you acquainted with that Tupperware dance and why is there an extra screw left over? Or did I just drop one of them under the carbs?Does less bodywork have to come off if I’m going to use the syncrometer? If that’s the case it would 100% be worth it haha
Nope, about a 10 minute job with practice ...Ah got it.
Not looking forward to pulling off the full sides and pockets/ cubbies. Seems like a right pain lol!
I decided to just get one to see what it’s like, but I’ll have to do an inspection of the water pump beforehand since if that’s leaking I’ve got bigger fish to fry at the moment than running as smooth as possible haha.
Smart!Nope, about a 10 minute job with practice ...
If you replace the 10mm hexheads on the lower side of the gas tank shelter with the proper socket heads and
replace the big side panel screwheads with 90112-MT4-000 Smooth side cowl bolts, you can remove all of it with a 5 mm t-handle and a JIS screwdriver.
Def worth getting the practice in!Air cleaner can stay on, what has to come off ,Seat, side cases, side covers ,top cover, side vents,gray storage panels, in that order. As Uncle Phil said, with practice 10 minutes. Synched mine Three days ago.
Why the gray storage panels? I don't need that.Air cleaner can stay on, what has to come off ,Seat, side cases, side covers ,top cover, side vents,gray storage panels, in that order. As Uncle Phil said, with practice 10 minutes. Synched mine Three days ago.
You were able to get to the vacuum ports without taking those off?Why the gray storage panels? I don't need that.
Ah yes, I’ve seen this one. Since he’s using that sk style syncrometer there aren’t any details on where the vacuum lines are.Have a look at this video, it should be helpful.
You don't need the vacuum lines if using the syncrometer.Ah yes, I’ve seen this one. Since he’s using that sk style syncrometer there aren’t any details on where the vacuum lines are.
Will take a look through the pdf service manual I found online. Just wish I had a physical copy :’( lol
Righto.You don't need the vacuum lines if using the syncrometer.
On my bike the vacuum lines were under the storage panels. Plus makes seeing the screws easierWhy the gray storage panels? I don't need that.
Practical, versatile kit...I like that Optimate tells you the accuracy of their unit is 0.5cm Hg.
How often do you perform a tune up like that? That’s very thorough.Practical, versatile kit...
I however see the carb sync only as the very last item of the tune-up...
- valve clearances checked
- new spark plugs installed, HT leads inspected
- cab bank fully inspected, cleaned and pre-adjusted (jets clean, idle screws set)
- new carb insulators installed
- all vacuum lines inspected (all possible leaks, like a ruptured diaphragm of fuel auto valve, eliminated)
- new air filter installed
I also place two office fans in front of the bike, to keep the engine near ideal temps as long as possible...
(once really hot the engine runs rich, thus starts to 'stomp' and hunt in idle...)
on older bikes the carb linkage itself can be a bit worn/loose, shafts might draw some false air, etc...
