What is the correct procedure to check the brake and clutch fluid levels on the MC on the handle bars. Here is what I do.
Clutch MC: Turn the handle bars all the way to the right to achieve a level position for the MC and then add the fluid to between the Lower and upper marks. This usually leaves a little bubble. Although when the handle bars are straightened there is more space in the MC compared to when it was turned all the way to the right.
Brake MC: Turn the handle bars all the way to the left to achieve a level position for the MC and then add the fluid to between the Lower and upper marks. This usually leaves a little bubble. Although when the handle bars are straightened there is more space in the MC compared to when it was turned all the way to the right.
Show below are the levels for the Brake MC on the left with the handle bar turned all the way to the left and the clutch MC with the handle turned all the way to the right.
