Shooting from the hip, main fuse and grounds tight too?battery terminals tight?
I didn't read it all through, thought still ran but just dash, lighting quit,the ground thing probably don't applyInfo on this here bad grounds most likely should be able to see how to fix easy investigate
There are few "probably don't apply" when you have an electrical gremlin. If the dash area and lighting shut down, check the 23 pin plastic connector behind the right headlight. Look for overheating/melting of one of the connectors (ground).I didn't read it all through, thought still ran but just dash, lighting quit,the ground thing probably don't apply
The 24 pin white connector is found sort of behind and below the left headlight. Above and near the right headlight is a yellow buss that brings together a number of ground wires (green). It's not really a connecter and doesn't come apart without destroying it but some of us have taken the ground wires out of it and cleaned them up if burnt and/or corroded then reconnected the ground wires together in a tidy insulated way. Corrosion at the yellow bus often goes hand in hand with a burnt and crispy 24 pin connector where the green ground wire from the yellow buss passes through the connector.There are few "probably don't apply" when you have an electrical gremlin. If the dash area and lighting shut down, check the 23 pin plastic connector behind the right headlight. Look for overheating/melting of one of the connectors (ground).
i've only ridden it twice since this happened both times it died everything shuts off the dash all the lights no power at all with the key on no lights no horn. I get it towed home. I put it on the charger. The battery charges up. I've tested the alternator and it's giving power to the battery but yet this is happening.More info please. Does it do this every time you ride it from a cold start or did it do this just one time or does it once in a while? Will it run normally after it cools off for a while? After it "shuts off" does it crank and not start or not crank over at all? When it "shuts off" and the key is ON do any lights remain on, does the horn work?
If the battery was going dead because the alternator was not producing charge current the bike would run a few miles gradually losing the dashboard. The dashboard would blink on and off before eventually going black. Shortly after that the fuel delivery system would lose pressure and the engine would stop running at least mine did when this occurred. Even at 10 to 10.5 volts on the side of the road some lights would glow dimly and the horn would make a ghastly noise.i've only ridden it twice since this happened both times it died everything shuts off the dash all the lights no power at all with the key on no lights no horn. I get it towed home. I put it on the charger. The battery charges up. I've tested the alternator and it's giving power to the battery but yet this is happening.
where can I buy the brushes and the regulator ?The 24 pin white connector is found sort of behind and below the left headlight. Above and near the right headlight is a yellow buss that brings together a number of ground wires (green). It's not really a connecter and doesn't come apart without destroying it but some of us have taken the ground wires out of it and cleaned them up if burnt and/or corroded then reconnected the ground wires together in a tidy insulated way. Corrosion at the yellow bus often goes hand in hand with a burnt and crispy 24 pin connector where the green ground wire from the yellow buss passes through the connector.
Cycle Parts Nation, Ron Ayers (these and any authorized Honda dealer). They all have similar part diagrams as this link:where can I buy the brushes and the regulator ?
i pulled out the alternator , is there a way to check the reg/rectifier ?Cycle Parts Nation, Ron Ayers (these and any authorized Honda dealer). They all have similar part diagrams as this link:
[/URL]
Look up your model and double check the VIN number to find the correct diagram set, then click on the alternator diagram. The individual parts are listed. Caution that most alternator repair/rebuild shops cannot bench test the gear driven ST alternator.
