Do some fall-of-potential testing while it's not running, such as checking for voltage between the battery + and the ignition + terminals, and between battery - and the engine case.
In other words, look for voltage between points that should normally be at the same voltage.
Any appreciable voltage drop will indicate a high resistance in the current pathway, which can be narrowed down by process of elimination with additional point-to-point testing.
