Need advice from the collective about multimeters
What model of Klein do you have? Time saving features are a big 👍 with me. Is the pictured circuit tester from Amazon? I was planning on purchasing one of these as well as some additional probes for the meter.
Mine is a MM6000, now discontinued. A google search turned this up: "The Klein Tools MM6000 Electrician's/HVAC TRMS Multimeter is a professional-grade, auto-ranging True RMS digital multimeter designed for heavy-duty electrical and HVAC troubleshooting. It has been discontinued by the manufacturer and replaced by newer models like the Klein Tools MM720 Digital Multimeter." Mine is well over 20 years old, bought from my favored electrical supply house.
That AI suggested MM720 can be bought from a number of vendors. It sells for $100 (ok, 99.97) from Hopot and Amazon, and comes with probes and a temp sensor (which I've used once to see if it worked, and never again.) The magnet is optional as are alligator clips, but the probes do have a plastic (easily lost) dohickey that covers most of the metal pick (see Amazon's picture).
Yes the auto test light was from amazon - just search for auto test light.
I've been accused of overthinking tool purchases (usually because I don't want to spend the big bucks for the best if it won't be an often used tool). For something like this, I'd compare several brands that caught my eye, then as I narrowed it down, I'd look at various models from one or two manufacturers. Yes, price would be a major criteria. I tend to like name brand mfrs, and Klein tools have stood up to heavy use for years. I admit I lusted after Fluke meters, but could not justify spending 3 to 5 times the price for something that could easily be broken. Back when I was working, Fluke had a reputation for very nasty customer service. No idea what that is like today.
Auto-ranging isn't really necessary for a meter you'll use for a given, known voltage range.
I suggest a meter that is meant to be portable. Look for 'pocket multi-meters'. Examples:
I bought one like this about 25 years ago and its still going strong (I have another newer Fluke and a HP 5.5 digit meter to compare it against). These were typically bought by various companies who did work for the US gov't and then sold as surplus over the years after they got a bit old. The specs on them are impressive, they're bulletproof mechanically (I think they're MIL-STD rated) and fly under the radar when people are looking for multimeters so they're dirt cheap. They are getting a bit old now, but the one in this link is returnable, so no big risk if it turns out to not be working as expected.
Nothing wrong with Harbor Freight DVMs...
yes and no.
I've owned a few of the really cheap ones they gave away for free years ago, that are about $7 or so now (Cen-Tech maybe??). On DC volts they are accurate enough, usually within one count when compared to my better meters. But when the battery gets low, they lose accuracy by a LOT, and as I recall it was even before the low battery indicator turned on to warn me. So they aren't very reliable unless you know its always got a fresh battery in it, but they're cheap enough to throw in a bag for roadside diagnosing and not worry about what happens to them.
I've never owned the more expensive models that HF sells, so I can't comment on those, but I'd suspect they're going to work well enough. DC volts for automotive work is the least demanding measurement on a multi-meter, so there's not a lot of variation between meters in that mode. And you're usually not measuring to several decimal places anyway. Measuring low resistances like coil windings may show differences between more and less expensive meters, curious what others have found because I haven't had to do that all that often so I don't have any first-hand experience on that.
One good example when a test light is the better choice is troubleshooting a non-operational starter. There are several switches in both sides of the starter relay circuit.
You would obviously clip the tester’s wire to a ground when testing for +12v, but you can also clip it to the battery + terminal when testing for points that should be at ground.
For a starter, if the relay doesn’t pull in, you would see if the coil’s ground-side terminal is at 0v, and then see if +12v is reaching the hot terminal when the start button is pressed.
Once you determine which half of the circuit is the problem, you would then test each switch, interlock, or other device to see which is not completing the circuit, bypassing it as a test.
Knowing the specific voltage is not necessary for this type of malfunction, and a test light is cheaper, easier to handle and read, is less fragile, needs no battery, and is auto-ranging. 😉
One good example when a test light is the better choice is troubleshooting.
Knowing the specific voltage is not necessary for this, and a test light is cheaper, easier to handle and read, is less fragile, needs no battery, and is auto-ranging. 😉
Lol.....I am chuckling.. because on one of my hairbrained whackjob intoxicated journeys, I threw together this circuit light tester... Oddly, it has come in quite handy...
I actually had something akin to this minus the wood box and battery pack many years ago. Ain’t nothing wrong with simple and cheap as long as it works!
A bulb with two clips connected across ignition points made it easy to know when they opened when setting the timing.
I even used the turn-signal buzzer once when I was setting the timing on my ‘73 CB750, just for the fun of it.
If
I need some advice on the purchase of a good multimeter to determine and diagnose problems when working on the ST and automotive applications.
then
You don't need an expensive multimeter. As long as it does DC volts, and can check for continuity, you're good.
And as mentioned a beep signifying continuity is a big help. Even a cheap $10-$15 Amazon or HF special can fill that bill. So an expensive meter is either for specific needs or just a flex. Eleventy-seven settings is sweet I'm sure. Even my steam-powered Fluke 77 is more often than not– overkill.
I use consumer lithium batteries is some things but a caveat — their life is extremely flat and a meter's battery may go T/U without any warning. So depending on what device you're powering it may not be the best choice. At home just swap it out. On the road it could be a problem.
second the beep
makes for a quick and easy check for continuity across an ethernet cable and check for any wires that might be shorted together
I've been using this Klein CL390 as a meter of first resort for over a year now and just noticed now that the clip is good not only for AC but DC Amps
I've got a very old Fluke DC clip which cost a fortune that I use so I'll compare the two
A quick look on Amazon has it at $115 Canadian I know one of the guys I work with has one very similar with a much better display in sunlight than mine so maybe the newer ones are upgraded display in any event pretty versatile IMG_3450.jpegIMG_3449.jpeg
... the clip is good not only for AC but DC Amps...
My Fluke does the same, however are clamps-on amp-meters sensitive to nearby EM hence only well suited/accurate for high currents (like machinery, AC compressors, washer/oven heater-elements, etc...), the DC setting therefore maybe good to guestimate cranking amps of an ICE starter motor...
Good is the MIN/MAX hold/memory function on digital meters, big assistance for diagnosing trouble out in the field (like observing current vs mains voltage to determine why a starting Inverter compressor trips OL protection...), haven't found a use in automotive diagnostics yet...
