I'd say a dark silver is a good description.Is the Loctite 8012 a silver color?
Look at the Honda manual or speak to someone who has one because I think some areas ask for MOLY Grease and others MOLY paste. Moly grease is fairly cheap. Unlike the paste.I need to pull my driveshaft out and service whatever lies within. does this stuff work in that area as well?
Probably the drive train. Nothing to worry about. A lot of folks have mentioned that.mine has 14k on it and when I leave in the morn, I hear and feel a groan (like a warped rotor) between my feet but goes away after a short ride(drivetrain warms up) leading me to believe I need a service of some sort?
With that low of mileage on your bike, I would suspect you may be hearing brake issues, and not driveshaft issues.mine has 14k on it and when I leave in the morn, I hear and feel a groan (like a warped rotor) between my feet but goes away after a short ride(drivetrain warms up) leading me to believe I need a service of some sort?
I have been known to groan early in the morning - especially if I have not had coffee.mine has 14k on it and when I leave in the morn, I hear and feel a groan (like a warped rotor) between my feet but goes away after a short ride(drivetrain warms up) leading me to believe I need a service of some sort?
Honda superseded the older M60 product with M-77 a number of years ago. It has been recommended in service applications across many Honda vehicles. When Honda supersedes a previous part or product it means it is the current item to use and Honda stakes their reputation on it.
Up until this moment I thought we may avoid a 200 post molybdenum thread .Honda superseded the older M60 product with M-77 a number of years ago. It has been recommended in service applications across many Honda vehicles. When Honda supersedes a previous part or product it means it is the current item to use and Honda stakes their reputation on it.
There are other choices of course but Honda now and for close to a decade says it’s OK to use.
Yeah, that way your spline will , and you'll have to take it in to be repaired at a cost of a new Goldwing!Honda superseded the older M60 product with M-77 a number of years ago. It has been recommended in service applications across many Honda vehicles. When Honda supersedes a previous part or product it means it is the current item to use and Honda stakes their reputation on it.
You keep believing thatHonda superseded the older M60 product with M-77 a number of years ago. It has been recommended in service applications across many Honda vehicles. When Honda supersedes a previous part or product it means it is the current item to use and Honda stakes their reputation on it.
Edit to add that unlike M60, M-77 tends to separate in the tube so if you do use it knead the tube per directions to throughly mix the product. Apply it as a uniform paste.
Maybe Mellow should close this thread, now that the OP has received the info on the proper product to use.
and deny Tx Red Rider the fun of reading 200 posts on the subject, no way!!Maybe Mellow should close this thread, now that the OP has received the info on the proper product to use.
