Thanks for the reply. I'll check that after I have gotten and installed my sparkplug capsPS: Weather on the left coast is also still cold and crappy.
I hope you used 100 mile per hour tape.Does this count as a F.A.R.K.L.E. I wanted to capture some real time voltage readings.
Called speed tape.I hope you used 100 mile per hour tape.
My friend in the paper mill said there is such a thing.
Have you checked the right handlebar kill switch? The contacts in these switches are prone to getting dirty. Had an issue with my 05 after sitting idle for the winter and traced it to that switch. Took it apart and cleaned the contacts and all was fine.Video 1 After 150km drive
Yesterday I went for my 1st long drive after all sparkplug caps replaced. 150km no problem until 1km from home. Landed home and removed the right side cover and measured the voltage at 5k.
Took the battery to Canadian Tire and it passed load test.
Video 2 Next Morning
This morning I started my bike, and Volts was over 14v. After 10mins of test of idle and 5k I think I still have the problem..
Yes. I had it apart and sprayed electrical cleaner inside while rocking switch off and onHave you checked the right handlebar kill switch? The contacts in these switches are prone to getting dirty. Had an issue with my 05 after sitting idle for the winter and traced it to that switch. Took it apart and cleaned the contacts and all was fine.
I don't know. Last year I called my local dealer and asked and at that time they said they would trouble shoot the problem... only thing is that it does act up all the time. So..... tomorrow I will remove the tank, plastic, air breather and check the throttle position sensor....Here’s a question, does Honda have a scanner or a scope for this bike.
I could look and see for myself, but if I disconnected the side stand switch will the bike keep running? Tomorrow I'm doing throttle position sensor maybe even remove the gas line from lower tank to upper tank and check for collapse. If all looks great Ma Honda is gonna see me. I'll make an itemized list and all readings that I have gathered. Retirement life is good but........Perhaps Temporarily hard wire past the kick stand switch and inspect its connected wiring for breaks on insulation? also hard wire past tip over bank angle switch for the same? once worked on a refrigerated trailer that would run perfectly fine at the shop. but would cut out frequently on the road especially in the city. found it to be a short in wire behind bulkhead in trailer caused by wire not secured and rubbed through insulation.
Ps: +1 on MacGyver volt meter
