Thanks Max... bought 'Ol Sliver' May 25th 2007 0km... like loosing a family member
You'll track it down.
Pete
Nope when it happens the speed needle stays constant. Lights stay on. It starts with a small hiccup then gradually reaches the big stumple. If I ease off the throttle it claims down, sometimes 4k is it when I going easy. If I open the throttle the rpm reaches 6k then bounce from 6k to 4k then 6k then 4k. . There is no back fireJust a thought;
Have you ever noticed your speedometer needle fluctuating?
An intermittent signal from a speed sensor that is just beginning to fail causes strange symptoms, but it often does not set a code until it becomes more than intermittent.
Thanks for your comment.. it happens in all gears. My relay did not cone in yesterday. So OlSilver will sit all weekendway over my head but maybe rpm limiter. Is this a separate sensor or part of the ecu? Does it do the same when in 3rd or 4th gear? Just re-read
post from @Andrew Shadow. sorry for the redundancy!
Just throwing an idea out there.
I know the knock sensor is normally the dreaded "code 26" when it is grounded out, but what is correct function if it does detect a knock? On a car, it adjusts a timing to try and protect the engine, I believe it retards the timing which reduces power/runs hot, etc.. Could you have an intermittent bad knock sensor and your ECU is trying to adjust? Just a thought that may have already been ruled out.
I would guess this is a sensor or wiring issue though. Every single time I have had an intermittent issue that presented with heat or water (rain) it was a bad sensor or connector. I had a Ford Expedition I got cheap from a dealership that would miss every so often (most noticeable on the highway). It did not have any stored or pending codes. I basically ran a garden hose on the engine/electronics until the miss became constant, which forced it to log a code. It turned out to be a cracked ignition coil that would function fine until hot.
Good luck!
Ryan
Good luck!
Ryan
Not old 2007 ST1300. I had it since new. Winterized last Friday and I will update next spring. I installed the new fuel pump relay 8 days ago and went for 2 , 90km drives amazing and looks promising, .. but I need 1000km for a good call. Salt arrived last Friday so......if this was an old points and rotor type ignition i would suggest replacing the capacitor.Please dont forget to let us know what the results are! (next spring if necessary.)
I'm gonna replace the fuel pressure regulator and gasket. Valve will be here next week but the gasket is on back order til atleast May 20th .
Any one have a source,
