EDIT: I should also mention that my exhaust smells rich. Always does, even on my former st13 2005. I thought these babies were set to run lean. If bike is running rich, what are the most regular culprits.
Okay, so now that my brakes seem good, I'll move back to fuel economy.
At 110kph (about 70mph) the best in getting I'm getting is just shy of 40 US mpg on the flats cruising without acceleration. (This is after odometer correction.)
Other people have reported 44mpg at 120kph (approx 80mph), but I drop to about 37-38mpg at that speed.
It seems that the 5 way tee often gets clogged. I had the shop check the 5 way tee last year when they opened it to replace thermostat (based on the fact that the engine was running cool, with the suspicion that the thermostat was stock open, but in truth they put in the wrong spark plugs with 11.5% too small of a gap!). Even though I asked for the five-way T to be cleaned, the worker only blew air through it and reported it as fine. So I do not know if the five-way t is properly clear or not.
Can the 5 way tee appear to be clean by blowing air through it, but still have enough gunk to obstruct vacuum air flow and negatively impact fuel efficiency...?
Is there a metal 5 way tee replacement...?
Also, even though my wax seal seems to be performing properly, can this get gunked up and negatively impact fuel efficiency...?
Here's the thing... If the bike's optimum fuel efficiency is 10% better than what mine is giving, I want to diagnose and rectify the issue. I don't look at prices of fuels like my wife does... "Oh gas is going up 5 cents tomorrow... gotta rush off to the gas station tonight!" But if the bike (as reviews regularly stated) can go 500km/tank, I want that instead of refueling just over 400km, and it brings me great satisfaction to have my tools in optimal working condition.
Is there anything else that could be checked...? The valve gaps were checked last year and reported to be perfectly within spec.
Thank you again everyone.
