You've said a lot...Regarding your question asking what affects fuel efficiency. Just about everything does, but below are some examples and ideas for you to mull over.
General state of tune, which includes spark plugs/wires, ignition system, engine valve gap, 5-way Tee, thermostat, etc., etc., etc..
How you ride- Twist the wrist, fuel consumption increases.
How you ride- Riding at an RPM that is to low for the current speed increases fuel consumption. The ST1300 likes to above 3,000 RPM. At highway speed it returns better fuel economy with an RPM closer to 4,000 than 3,000. Many of us tried to convince you of this in your previous fuel efficiency thread where you were adamant that the ST1300 is geared to high and that the engine RPM is always to high. At the time you were asking about a means to modify the transmission and/or the final drive to lower the engine RPM's. If you remain convinced of this and are constantly lugging the engine the fuel efficiency will be affected.
Where you ride- lots of stop and go, fuel consumption increases. Lots of elevation changes, fuel consumption increases.
Tire pressure- The lower the tire pressure the higher the fuel consumption.
Strong head-wind, fuel economy suffers.
Obstructed airflow to the induction system. This is not limited to the cleanliness of the air filter. An obstructed intake tract has the same effect. e.g. Mouse nest.
Dragging brakes.
Riding the brakes. Some people keep to much pressure on the brake lever in anticipation of an needing to perform an emergency stop instead of just covering it in preparation. They don't realize that they are activating the brakes ever so slightly.
Excessive resistance to wheel rotation other than brake dragging. e.g. Failing U-joint, failing wheel bearings, improperly installed wheel bearing/wheels.
For comparison purposes to give you some exact real-world numbers calculated by dividing the consumption in to the distance driven, not based on the results of the on-board computer, below is the fuel efficiency numbers for my 2009 ST1300.
Note to the number crunchers- If you do the math it might not work out exactly because I use Excel formulas that I have set to round up/down. It is more than close enough, I don't need precision to the 5th decimal place for calculating MPG. I generally ride between 100 and 120 KPH GPS reported speed when on the highway.
The average fuel efficiency of all miles ridden since the motorcycle was new, so a true average, is;
55.5 miles per imperial gallon, 19.7 Km/L, 5.1 L/100 Km, 46.2 miles per US gallon.
The last time that I went to Nova Scotia it was getting to/from the Cabot Trail and the surrounding area. It was probably a more sedate ride than what you might do because I was with someone older, so there was no knee dragging going on. The numbers will be a little higher because of that, but not enough to explain the difference between what I am reporting and what you report.
My average fuel efficiency on that trip was;
57.6 miles per imperial gallon, 20.4 Km/L, 4.9 L/100 Km, 47.9 miles per US gallon on that trip.
Several things, like riding the bike, I'm WAY past... Although I'm a cr@ppy auto mechanic, as far as riding beasts I'm very well aware of brakes and ideal gear usage.
Stated above somewhere, I have observed and calculated based upon fill up consumption and km's driven, then compared to the onboard display. I know its error is consistent, and I calculate for this.
So far this tank, 90% highway driving @ 110-120kph, I've driven 237km and I'm down to 3 bars... Less than half a tank. Driving for fuel consumption not for the smiles. I'm getting AVERAGE 38.88mpg (US) including the last 3 tanks. I've gotten 47mpg on the flats, which is pleasing to me.
It seems that:
1. After my brake job, it took a few rides for them to settle in. I can feel when the brakes are, or aren't, binding even when I back down my driveway, and at stops when I'm on a slope (based upon how easily/quickly the bike moves clutch-in when brakes are released).
2. As someone commented on Facebook, low altitude, cold ambient temperature, and humid air really take the pi$$ out of this engine's fuel economy.
3. The gearing is NOT ideal for European and American roads. It is ideal for Japanese roads. I know this thorough direct experience, and I know the Japanese cultural mind intimately. They are insular in thinking. "Sakoku jidai" still exists in their thinking. My 4 cylinder cast, and my 6 cylinder car, operate near 2500rpm at highway speeds. Any more than this and you end up cruising in passing gear, affecting mileage detrimentally. The engine only needs to produce enough torque and power at highway speeds to overcome wind and rolling resistance, as well as to overcome the inefficiency of the engine. The faster the rpm, the greater the loss (ie: more energy is used just to spin the engine, fears, cramp shaft etc).
I'm cr@p at auto repair but I understand this mechanical concept stuff quite well. With different gearing, this motorbike could easily get an extra 15% fuel economy. You can disagree... That's fine.
My Shadow 750 was geared from factory at about 5000rpm @ 100kph. And this is for a LONG STROKE V TWIN! First thing I did was change the sprocket (I hired a Japanese mechanic who knew how to do his stuff correctly, unlike my experiences here) which DRASTICALLY improved EVERYTHING about the gearing. Then I had a custom belt drive kit made.
