I heard rumors that the position of the windscreen can affect MPG. I have found that is not true. I don't see any measurable difference whether the windscreen is up or down.
Are you going by the MPG readout on the dash or by the amount of gas you put after a certain # of miles.Riding at about 120kph I got about 43.5 US mpg
I've measured both and determined the offset, so I use this calculation standard. Good point though!Are you going by the MPG readout on the dash or by the amount of gas you put after a certain # of miles.
I suggest that you fill up, reset tripometer, drive 3- 4 tanks and do the mathIf I cruise smoothly at the speeds I've given, the results are as given.
To get 58 mpg at 110kph to 120kph seems impossible to me...
This is so much of it.Riding at an RPM that is to low for the current speed increases fuel consumption. The ST1300 likes to above 3,000 RPM. At highway speed it returns better fuel economy with an RPM closer to 4,000 than 3,000.
I didn’t see it specifically used in the thread, but wouldn’t put too much credence in the instant mpg per gallon read out on the dash.
Temperature today from 25 to 29 degrees Celsius.
Riding at about 120kph I got about 43.5 US mpg.
Seems good, for sea level and humid.
My idle wanders a slight bit. (This is different than the idle dropping when the rad fans turn on...)
Is this slight bit of wander normal...??
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Do you remember the recommended shift points in the Honda users manual...? 5th gear by 50kph... lolAlmost never used 5th gear unless I was on a freeway or doing 75mpg.
I don’t like lugging the engine, and making it work harder.
I see too many people shift up to 5th gear way too quick, and doing 40 mph in 5th.
I find better response, in the proper RPM range, and don’t have to down shift, then up shift to pass someone etc.
I find I get better MPG riding this way as well, at least for me.
Air filter is part of my regular maintenance...I might suggest checking the air filter (when I bought mine it was unbelievably nasty) before digging into the fuel system. I can also post the troubleshooting guide from the shop manual if requested.
