- Joined
- Feb 11, 2006
- Messages
- 9,682
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2024 Miles
- 008131
- STOC #
- 6651
DCT in auto or manual modes doesn’t allow holding a higher gear than road speed allows. It’s impossible to be in 2nd or 3rd unless the bike is going fast enough to shift into those gears and if you go too slow in an gear it automatically downshifts to the next lower gear to prevent stalling. Minimum upshift speeds are programmed into the transmission control module as are minimum downshift speeds.
However the brakes are powerful enough to overcome engine thrust so the only thing could burn the clutch up in a short time is the starter clutch pack was forced to slip and to slip at a high engine rpm. High rpm’s were required to offset the braking force required to keep the bike going slow. Otherwise the bike wouldn’t start moving. Slipping at low rpm in the friction zone is the technique we learn to perform slow speed maneuvers and done within limits isn’t harmful to the clutch in a manual transmission or DCT.
There are tons of instructional videos on the net on how to do slow speed maneuvers with DCT bikes. You set a steady fast idle and control speed with by lightly dragging rear brake. You can also set the throttle at entirely too much rpm and hold heavy pressure on the brake. This guy proved you can and what happens when you do.
