I ordered the flush fit fasteners. They should be in on Wednesday so I can do some side by side comparisons then and maybe post up some pics.
Alan what didnt you like about the Lowe's clips???? I just cant justify $5 for a little plastic clip!!!!!![]()
Dennis Kirk has these listed for Gold Wings:
low profile
standard
10 for $7.99 . I'll get a pack of the low profile "rivets" along with some other stuff I'm ordering and report back.
I believe that these two are the 8mm fasteners, such as used on the front of the belly pan. The smaller (6mm?) ones that go on the majority of the bodywork are the tough ones to find.
low profile
standard
Had to do a little searching to find the link, but these guys might be helpful.
I've never used them, but if I could find the correct part, I'd certainly order from them.
http://www.thefastenerwarehouse.com/page/page/568575.htm
No affiliation, etc., etc
That's a good help, thanks for posting it.I know this is an old thread, but this site gives specs on the plastic rivets.... might help someone. https://www.rivetsonline.com/blind-rivets/q-rivets-structural-blind-rivets#1
Try your local car trimmer or auto factors. Much cheaper!OK whats the secret....those flush pinned plastic clips on the maintenance panel, lower side cowls and front lower cone made me feel just down right stupid.:rocket1: I destroyed about 4 of them in frustration!! Made changing the oil a not fun job....geeze. So what is the easy way to remove them and re-use them. :bow1:
Also, when ordering them over the net, are they really $2-3 each or for the amount needed for the panel. 3 different ones as well!! Whats up with that!!!!????
www.boltmotorcyclehardware.com
you'll want the M6 Nylon push rivets #2005-6sriv, and the M8 Nylon push rivets 2005-8sriv.
They are $5.99 for a pack of 10, and are a better grade nylon (not plastic) so they don't break as often.
