Bones
Your Humble Scribe
Probably a dream ticket solo, too. Just depends what show you're buying tickets for.
From post #10 above:What was the seating position like? How straight up were you versus lean? Thanks.
664 lbs wet, full of fuel. I agree, it felt lighter than the ST and the weight seemed to be carried low.One thing I forgot. They guy that looked at it with me and I both thought it felt light. We both leaned it over quite a ways and had no trouble pulling it back up while sitting on it. The weight must be low.
"Wet weight (ready to ride), 301 kg (662 lbs)"I think the ready to ride weight, per the Triumph website, is 664 pounds without the saddlebags.
Honda lists the curb weight of an ST at 730 lbs. That would make the Trophy lighter by 68 lbs (a factor of just under 1/2 Bones ).Without panniers about 36 - 45 lbs lighter than an ST depending on equipment.
Fully fueled and ready to ride an ST1300 without ABS weighs 700 lb without panniers. I know - I weighed mine with and w/o panniers with a full tank of gas. 720 with panniers. ABS adds 9 lbs so the 721 and 730 curb weights Honda gives are accurate. Thus 700 - 664 = 36 and 709 - 664 = 45. If the Triumph weight is 100% fueled and with panniers then I do need to add 20 or 30 lbs to the difference. I think the Triumph bags are double walled like BMWs so they are probably a bit heavier than Honda's are.Honda lists the curb weight of an ST at 730 lbs. That would make the Trophy lighter by 68 lbs (a factor of just under 1/2 Bones ).
Your bias is showing ......... again.......Anyway, it seems BMW still builds the heaviest sport tourer by a slim margin.
ooohhh... aaaahhhh.. I like that..Your bias is showing ......... again.
