Mark B
Wonder who that was ??????
The only clue I'm sure of is that every 'universal' tire I have seen shows opposite front and rear rotation.I still don't "get" the why, for reversing a m/c rear on the front. Front on the back?
I withheld the name to protect the guilty.Wonder who that was ??????
I’m no car tire fan on a motorcycle. But I was there when this happened. Thank you John and Raymond. Giving the situation I would have done the same thing to get me home. Would not have been afraid with John and Raymond assisting me to mount it. I would have ordered a PR6 when I got home. But car tires are going on my Cam-Am Spyder. I will pay the outrageous amount of money for tires on my Trophy SE.One thing to keep in mind, whether you’re pro or con on darkside, a $88 car tire from Walmart will get you home, when you’re a long way from home on a Sunday. One of the riders at my RTE, ruined a tire on his trip here. After a trailer recovery, and some experienced help from @W0QNX , a car tire was mounted, using only tire irons. Tire irons are available at most auto parts stores or Harbor Freight.
Rear tire needs traction for acceleration, front tire needs traction for braking.The only clue I'm sure of is that every 'universal' tire I have seen shows opposite front and rear rotation.
My best guess is that the tread sipes work better differently for each position on the bike in rain.
Makes me wonder why I even bothered to reply...Rear tire needs traction for acceleration, front tire needs traction for braking.
So everyone could agree with you.Makes me wonder why I even bothered to reply...
Tom
GYTT = Goodyear Triple Tread automotive tire mounted on the rear.
Goodyear Triple Thread tire for my ST1300
BT45 = Bridgestone Battlax Sport Touring motorcycle tires. Many people use a BT45 rear motorcycle tire mounted on the front in combination with an automotive tire mounted on the rear to get extended mileage out of both the front and rear.
Battlax Sport Touring BT-45
I am not on the dark-side. I run motorcycle tires.Thanks Andrew. Who did the mounting and balancing for you? I'll talk to the Honda dealer about this, they may do this all the time on Wings.
I’ve put the CT‘s on the rim with spoons, but never successfully taken one off. Harbour Freight (Princess Auto in Can.) sells a tire machine for do-it-yourselfers that some guys have used successfully to Re and Re a rear CT. I get mine done by a member from here in Edmonton. He’s really good at it, he’s done dozens of them for different guys in Edmonton and that’s what he uses. Theres a company in Montreal that will do it as well, if that’s an option for you. PM me if you want their name n number.Thanks Andrew. Who did the mounting and balancing for you? I'll talk to the Honda dealer about this, they may do this all the time on Wings.
What company? I fleetingly contemplate dark-side every now and then. If ever I decide to give it a whirl, it would be good to know. Posting it could benefit others as well.Theres a company in Montreal that will do it as well, if that’s an option for you.
Awesome, Thanks!!I’ve put the CT‘s on the rim with spoons, but never successfully taken one off. Harbour Freight (Princess Auto in Can.) sells a tire machine for do-it-yourselfers that some guys have used successfully to Re and Re a rear CT. I get mine done by a member from here in Edmonton. He’s really good at it, he’s done dozens of them for different guys in Edmonton and that’s what he uses. Theres a company in Montreal that will do it as well, if that’s an option for you. PM me if you want their name n number.
I use a Pirelli, I think the most recent is a P7, whatever their most recent P model is. My 3rd one now. They are consistently a full half inch narrower that the GoodYear TT. I get about 25k miles out of one, run it at 28 and 30 when fully loaded. And they dont have the Hankook ‘wiggle’ that I found with a Hankook and many others also complain about.
Sorry to take so long to get back to you, I don’t check in here all that often, obviously.What company? I fleetingly contemplate dark-side every now and then. If ever I decide to give it a whirl, it would be good to know. Posting it could benefit others as well.
What about fuel economy...??I am not sure that it makes that much difference in handling. The rear MC tire has a thicker tread, so there is more rubber, so it lasts longer on the front.
The key to using a Ct in the back is lower tire pressure. I run 26 psi in the rear with the Hankook, so there is more sidewall flex and there is no lift that you would get with higher pressure, the best part is that it gives an incredible smooth ride.
I saw no difference. 12k miles.What about fuel economy...??
I know them well, I have had tires changed there.The company in Montreal is VT Motorcycle Maintenance.
Having spent the vast majority of my ST miles on rear only Darkside, I can say that there is no appreciable decrease in fuel mileage. I’ve ridden with other ST’s on day rides, we fill up at the same time and the same place having gone the exact same distance at identical speeds, and our mileage is identical, the only difference being I’m on a car tire, he’s on a bike tire. And, realistically, why would it be any different?What about fuel economy...??
I've read about DarkSiding a lot (and with my screen name I should be amenable to it) but even with reports of lots of people doing it trouble free, it still just seems so wrong and dicey to me, with potential danger lurking!
