BakerBoy
It's all small stuff.
Bill your collars look like correct orientation to me, but it looks like the left one isn't seated as deeply as I'd expect (could just be an illusion on your pics). Pics of mine from a few minutes ago:
I took a stack picture of the right and left front brakes...your's look similar, but I can't be sure from the pics. You should see a very short amount of the piston sticking out of the caliper (about 1mm-2mm), and it should be very clean if they did the right job on it. You can see one of the pistons on mine (it is brass colored to the right of the right pad in the first picture below).
Based on what you're describing... If it were mine, I'd push each caliper by hand (after making sure the piston appears clean) towards the rim. It may require a bit of force and jostling, but each should move a little for you. (They're made to move left to right slightly, called floating, to deal with the pad wear.) Then spin the wheel....you should not hear any brake pad drag once you do this. If that cleared the 'rub', then I'd be looking into why the calipers aren't 'floating' on the discs.
