I've decided that some people need to stay away from tools and mechanical/electrical decision making.Houston, we have a problem!
Definitely found the problem or at least part of it.
There is no fusible link to the left of the battery. Well, I'm being my polite Canadian self when I say that. The truth being that there is no damn fuse board or its wiring either. It's completely stripped from the bike.
Consider it a challenge. I've rebuilt worse over the years, but with the assistance of a wreck or two.....and a lot more time to spread out the expenditures.Think someone has picked the best bits including tupperware and left me with a right pig's ear to sort out.
Am not giving up though. It's made me more determined than ever to see this through.
Hi Kiltman,The two photos are from two different charging models. Post 81 is the 28 amp unit with the external Voltage regulator/rectifier. That increases the possibilities of malfunction. Check that white connector to the VRR. Also trace back the thre3 yellow wires to a red connector, check or. That main relay connector can also be an issue.
The fusible link is part of the 40 amp alternator circuit. Keep that as that is crucial when you upgrade the 28 amp alternator to the 40 amp unit. ( but I think you have acquired the post 96 engine with the 40 amp alternator or is that engine missing the alternator when you got it?)
Yes it should have come with your 99. It will also be needed in the event you upgrade the 95 to the 40 amp alternator. (Consult a wiring diagram for the two years and compare and you will see where that fusable link comes in on the 96-2002 model years)Hi Kiltman,
I've just re-read your last message. Are you saying that the fusible link in the black box as pictured on my 1999 daily didn't come with the bike in the first place?
Colo(u)red wiring diagrams: http://www.st-riders.net/index.php?topic=3908Will definitely look at the other diagrams to compare the differences.
Yeah, I printed out a couple of copies and carry one on the bike full-time.Thank you John.
That's a massive help. The colour coding makes a big difference.
The red connector has been removed, instead they have individually hooked up the spade connectors. Pull the right front one inspect it. That’s the main red wire that we’ve been talking about. There’s a good possibility that it may be burned out.When I get home I'll open up the red connection into the relay and photograph it
