kiltman
- Joined
- Apr 27, 2013
- Messages
- 3,270
- Age
- 68
- Location
- Stratford, Ontario Canada
- Bike
- 2002,ST1100ABS
- STOC #
- 8826
Thank you, thank you.
The connectors to the main relay look good. At one time the previous owner had an issue and he opted not to use the red connector housing, instead used individual spades which work just as well. Do you get power out of the red wire with the key on?
When you press the starter button do you get power at the yellow wire/red tracer at the main relay?
When you turn the ignition on do you hear the main relay click?
Many owners bypassed the red connector for the three yellow wires and instead used crimped connectors or soldered the three yellow wires individually to each other. If your plan is to upgrade the alternator just clean that connector up as you will not need those wires with the 40 amp unit.
At the ignition switch is a red wire with a blue tracer need to see if you get power to it ( with key on)
I couldn’t tell if your light Sabre lit up when you checked the main relay, please confirm you had power there.
Thanks
Thanks
