Hi All,
Firstly, thanks for the inputs / and thoughts so far…. . I have eventually, with the help of some people of here came up with a feasible plan. (in my mind, anyway !!!)
ICE / Gearbox, clutch, water pump assembly
Gearbox – Yes everyone, I am going to try with the first option to utilise the cut down ICE engine and cobble a means of coupling together the EV motor (bevel belt, Meshed gears, chain sprockets.) so, I can get an effective water-cooling system also.
I am expecting mechanical losses from this setup, but I will try and reduce them were possible, and eventually see a result.
Once installed if this proves fruitless / and not to my satisfaction I will scrap the gearbox idea and revert to an EV motor direct system.
Plan is to keep the weight, especially the batteries low down.
The Electric EV side
There was a great deal of help, and thanks especially to guys in endless sphere forum and
c70r and for his thoughts on this:
My current thoughts for the powered system are:
Batteries
Both assemblies will be mounted in each side pannier. (some strengthening may be needed.)
Either:
Plan A - 2 off - 2012 Chevrolet Volt EV 88V/5kWh battery pack
Lithium Battery Module - LiMn2O4/LiNiO2
Contains 24 cells or 2 packs of 12 cells.
Each cell is nominal 3.7V, max voltage 4.15V - measured 34Ah.
Continuous current is 4C = 140A, short time 210A.
Length: 47cm (18.5")
Width: 18cm (7") top / 24cm (9.5") bottom
Height: 28cm (11")
Weight: 38kg (84 lbs)
Link below.
m.y. 2012 88V 45Ah nominal
evshop.eu
Plan B - 7 x Nissan Leaf 2018 Modules will get you the 28S (116V) and 112Ah to giving a total of 11.6kWh
The EV drive motor:
My current thoughts now point to Zero 75-7, as this looks to have better specification. The previous 20kw BLDC motor, was suggested to be underpowered for this setup.
54 hp or 40.26 kw
420A @ 116v
The only issue with this motor, is it is rarer than hens’ teeth to find. A good secondhand unit is hard to find, so it maybe some time until I acquire one.
The controller
the Sevcon Gen 4 Size 6 if you decide to go the Zero motor route due to the 116V capability. The controller, programming cable and software can be sourced for around £1100 brand new from a dealer in the UK. (6Kg)
Hopefully I can find a secondhand unit out there!
DC- DC controller –
This is to power your lights, indicators, horn etc. (these I seen at Maplin’s / RS for Previously about £30.
Throttle / twist grip -
the throttle like will be a Domino, as these are supposed to be the best. (not found one yet!)
This basically gives me a Zero S/DS like bike but in the shape of a tourer.
First job is the engine conversion. (while I hunt for the EV parts in the background.) I will post photos as it progresses.
Regards and many thanks to, c70r, I owe you a pint.
tony
