Clever, I like this idea. But I don't like the GPS powered straight off my battery for an hour or so every time I shut the bike off. I do take it off most times, but if I'm camping, likely not.I am a fan of a timed switch as well. I would consider a timer module on the switched power from the fuzeblock so that after you shut the bike off, the line continues to be live for the set duration. The benefit is no need to run a separate switch. The drawback is it is live for the duration every time you shut the bike off. That may not be a huge issue. If you are walking away from the bike, chances are you may be taking the gps with you anyhow, or you could shut off the unit.
