Based on the PIA (pain in ass) factor, they may not go back on.Thanks - that's what I was wondering based on someone's experience.
And I'd say 100,000 miles is sufficient experience!![]()
Once I cut the centers out, I could mount them with the headlight assembly in place on my non-ABSII ST1100 from the top.Based on the PIA (pain in ass) factor, they may not go back on.
Yes, I replaced my bulbs on a non-ABS 1100 just by removing the shield and plastic under it and reaching in. I cut the center of the boots and had no trouble reinstalling the second part of the bulb through the boot.Once I cut the centers out, I could mount them with the headlight assembly in place on my non-ABSII ST1100 from the top.
But it doesn't sound like it's much of an issue either way with Paul's lengthy experience running without them.
When you say failed attempt at something that would work are you talking about the boots?I think the rubber boot is not necessary with the LEDs. The boot is necessary for the halogen bulb because water on a hot bulb will cause it to crack and fail.
I destroyed my boots many years ago when I was trying different LEDs in my failed search for something that would work.
I would guess that I have been running the last 100k miles without boots on. My bike sits outside all year long and is a bit ragged but loved.
Not a garage queen, but a workin mule.
Ah, I wondered. I was confused and thought maybe you were saying none of the LED's were any good. I had read the threads where you were going through the testing and I had installed a version of the H4 last summer based on your results.No. Several years ago I searched for H4 leds that would work in the ST. None were found.
So I contacted a OEM and told them how to fix their product to make something that would work.
The current versions of the H4 with the proper shield, correct led shape, correct focus was the result.
A long story, but now you can find good stuff from the rest of the OEMs....
I just turned the boat around and got it going in the right direction.
All the self proclaimed experts will still tell you that it will not work.......
What do you mean with "cutoff line " Power cut - as in a fuse ?I have done a LED upgrade on my ST1100. Did it by removing the windshield and the plastic cover over the headlight that gives access to the rear of the instrument cluster and the back of the headlight..... Pick your LED carefully and make sure they have a good cutoff line!
I think he meant that the bulb is constructed to aimed properly and not a flood light or blinding oncoming traffic..What do you mean with "cutoff line " Power cut - as in a fuse ?
And I thank you again for all of your work on this (and again for the free lunch when I was out your way)!No. Several years ago I searched for H4 leds that would work in the ST. None were found.
OK ! I got the F2 's . For a moment I saw my beloved ST going down road like a Fire ballI think he meant that the bulb is constructed to aimed properly and not a flood light or blinding oncoming traffic..
BTW, you've got the prettiest color of all the ST1100 colors!OK ! I got the F2 's . For a moment I saw my beloved ST going down road like a Fire ball
I love that blue but we never got it over here.
Well Thanks !BTW, you've got the prettiest color of all the ST1100 colors!
If you look at the headlight assembly closely, there is an opening between the left-hand and right-hand reflector assemblies. i.e. They are not two completely separate reflectors. Under the North American regulations this lack of complete separation means that this is considered one reflector assembly, not two. If I remember the details correctly, there is some stipulation in the North American lighting regulations that limits the maximum wattage of two bulbs that are in the same reflector to 45 watts maximum each. This is why the tabs are located at different locations than the standard H4/9003 bulb. It is specifically to prevent regular automotive bulbs, which at the time were rated at 55/60 watts, from being installed. The only bulbs that will fit are the ones with the correctly located tabs, which were all limited to 45 watts.Why would Honda not use automotive type bulbs?
I don't know if it is possible, but are you certain that your new LED bulbs are installed in the correct orientation. From memory, I was under the impression that @spiderman302 has often said that when installed correctly the wires existing the bulbs should be at the six o'clock position, as in the second photo in post # 7.I could never get the covers to fit around the new bulb decently with the wires coming out the top.
