Try listening for an air rush as you open the gas cap after riding for a while. If a vacuum is building up in the tank it could take a while before it caused a problem.
Temp was 18 to 23c todayTry listening for an air rush as you open the gas cap after riding for a while. If a vacuum is building up in the tank it could take a while before it caused a problem.
Sorry, help some of us along by what you mean.there is a blink code procedure in the manual but its a pretty archaic system ... definitely no PIDs here
I put the old vacuum lines back on idles perfect, I can Rev it with no problem. Right now I can hold it at any RPM with no cut out. But it will time to time on the road. Sunday it worked horrible from Halifax to hone about 85km . These are the plugs from yesterdayWow you're not having any luck yet figuring out this issue!
Good idea to let Honda have a quick peek but not too long I hope, they are expensive.
The only engine cutting out comparison I can relate to with my bike is what I experienced a few months ago. I had done a throttle body sync ,put it all back together and tried to start the bike. The idle was real irratic and when I held the throttle on steady ,the rpm would bounce up and down real bad. I had a code though. It turned out one of my vacuum hoses on the T had fallen off where it attaches to the intake after I finished working in that area. Couldn't believe how bad the engine worked with just that one hose off. Hopefully it's a simple quick fix for you!
Thanks for your reply..its always the same right ? Even after the new pump the issue feels exactly the same ?
a pressure regulator can cause that BUT don't forget the rest of primary fuel system. Vacuum to regulator. Rail return line . pressure line to rail. pump pick up tube , tank to tank venting, tank to atmosphere venting, pump wiring including any relays.
there is a blink code procedure in the manual but its a pretty archaic system ... definitely no PIDs here![]()
Let us know how it goes @Tdinova - what a pain for sure.
Having said that, there IS a cause and you will find it.
Pete
