Until now did I not solve anything.
bike works normally until it reaches 5500-6000 rpm in all gears and neutral
I checked :
- Intake air temperature sensor(IAT)
- Knock sensor
- MAP sensor
- TP sensor
- Engine colant sensor(ECT)
- Ignition Pulse Genereator
- Cam Pulse Generator
- All 4 injector conection
- Fuell cut-off relay
- ECU
- Fuel Pump
- Coils
I opened the connectors listed and I spray contact cleaner, blew air and I reconnected
I removed :
- All 4 SparkPlugs (iridium and are in good condition)
- I removed the fuel pump and I checked the fuel filter(secondary tank and fuel filter good condition)
I go to the Honda service and the mechanic couldn't connect the bike to the tester and does not know what is causing the problem....
