So I thought I would post an update since it has been about two weeks.
Since then I have done the following.
$25 Replaced petcock (after receiving the wrong part twice. vacuum petcock was advertised and pictures but a manual petcock was sent instead that wasn’t the right for anyways finally had luck with the third vendor).
$10 the original OeM fork brace (still in the mail)
$10 fork brace reinforcement (not stock but helps provide more strength to the allumimum OEM part by fitting under)
$175 Brand new tire set, oil filter, air filter and 4 spark plugs from the dealer. Yes all of this for $175 because my mechanic works there and hooked me up.
$40 Original grill and Honda emblem that was missing (makes the front look way better
Changed all fluids.
adjusted the shifter because It was loose andangled way lower than it should have been.
adjusted and tightened the clutch (we think the bike was dropped as the shifter and clutch were both loose and bend a little)
sealed a small leakfrom the coolant overflow tank nothing major
power washed the bike here is a video
